BOSCH DISHWASHER
  • #17286
    PGS
    Hi ive got a heating element to change on the above dishwasher MOD SGS0922GB and it looks a right pig of a job. Any tips on this one or is there any service bulletins , or any advice would be much appreciated cheers Paul.
    #173653
    supertramp101
    Re: BOSCH DISHWASHER
    hi paul i u have to take tank off or thats the way i do them i have herd of people who up end them but can be a bit messy me tnks (i never tried 😀 )
    or insted of fitting all the box remove from end and do throu r/h side (never tried that ether) its not a quick one and also be carefull of side tank thin plastic back supertramp101
    #173654
    First remove the top panel and counterweight, the side panels and front door panel. Unclip the door spring cord from each hinge, release door hinge retainer and rest door on the floor. Remove baskets and top spray tube, remove nylon tub seal clamps. Unhook water matrix clear of the tub. Take off screws holding tub to base and gently lift tub clear.
    You now have full access to all the components in the base. :tup:
    Reassemble in reverse order ensuring to align the tub onto the black rubber seating ring carefully before clamping in place ❗
    #173655
    Honeywood
    I’ve sent you the service manual for the SGS09L02 and hope it’s similar.
    Good luck!
    #173656
    Honeywood wrote:I’ve sent you the service manual for the SGS09L02 and hope it’s similar.
    Indeed it is!…How very kind of you…can I have a copy? 😛
    #173657
    Honeywood
    No probs, done! 😀
    #173658
    PGS
    Thanx million guys dishwasher now on test.
