Bosch dishwasher
  • #30003
    Gamba
    Hello newbie here. I have the following problems.
    8 year old dishwasher failed to empty water after cylcle then failed to fill and kept running dry without turning off .
    I took side panel off cleaned tubes and the filling unit. Turned machine on. Now all it wants to do is empty water. I filled the machine manually and it just empties and nothing else.
    Next I took front switch panel off and now the on button won’t stay on.
    DOUBLE DOH! 😳
    #225486
    Re: Bosch dishwasher
    Model number, please……..
    nomadPaul
    sounds ike the base could be full of water…but as Penguin says, model number required – should find it etched o n the top of the inner door
    #225488
    Gamba
    Been away for a month 8) . I found a number on the door, SGS5312GB/12. Hope this helps…
    #225489
    This is the machine built on a tray. If it floods, a polystyrene float rises up and lifts the red rod, working the over-ride switch next to the level switch. Check for water in the tray – you say you have stripped the matrix, so check for correct re-assembly and location of the red rod.
    Gamba
    Thanks Penguin for your patience and quick response,
    At last some progress after thoroughly cleaning the matrix I now have water entering the machine but I have to hold the switch – it is not catching. I will take this off and investigate (with the power off of course!).
    #225491
    Gamba
    SUCESS!
    I took the switch apart (how many springs????). The small brass wheel had come out of place. All back together and hey presto now working. Again thanks Penguin – YOU THE MAN…
