Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch dishwasher
- This topic has 15 replies, 5 voices, and was last updated 18 years ago by
fasetester.
April 1, 2008 at 2:58 pm #35668
fasetester
Participanthi guys went to repair a bosch intergrated dishwasher pump running on . disconnected the power plus water pulled it out layed it on it back. removed bottom plate float and plate soaking with water and glare . cleaned it all up put back togeather tryed on same problum no water coming in pump running went throught the same thing again checked pipes for blockages no blockages found no leaks . what is the timer for that is screwed into the sump and then inside the sump their is a gray domed fitting could that have caused it not to fill how does it come out. plus what is the big gray box for where the hose connects to the mains under the sink then when i tryed it for the last time the pump was still running every now and again you could here some thing clicking took of the side panel checked the valve ok i could smell something burning is there a way to reset this dishwasher thanks fasetester 😕
April 1, 2008 at 3:07 pm #247525Martin
ParticipantRe: bosch dishwasher
Bl**dy hell fase, you typed that without drawing a breath by the looks of it?
What the hell model is this beast anyway? 😕 (Rule No: 1 mate 😉 )
April 1, 2008 at 3:58 pm #247526fasetester
i know i should have looked at the number i got was model or type SL15JIB dont know if it is right or not from the info martin could you say why the beast would not bring in water . fasetester.
April 1, 2008 at 8:36 pm #247527superfix
No it certainly aint the right E-Nr.
It should be something like SGV????GB/??
As for why it wont fill, can’t really say until you give us an E-Nr.
April 1, 2008 at 9:11 pm #247528fasetester
hi guys any bosch experts what do you think. the mushroom float how does it come out. and the timer motor that goes into the in line heater box how does it work and what does it do can it cause the dishwasher not to fill. what is the gray box for just before the connection to the shut off valve under the sink the hose goes from their to a little round box it is like a acostop. with a thin wire plug going to it what does it do and what kind of problums do the cause and then from the other side of acostop blue hose to the iwms i think thanks fasetester.
April 2, 2008 at 7:18 am #247529Martin
Give us the ENr number fase please, it’s etched on the door. Meanwhile, I’ll leave this one to Greg methinks 😈
April 2, 2008 at 6:20 pm #247530superfix
Still no E-NR, it would help massively you know :rolls:
The mushroom is the overfill safety s/w. It needs to be snapped on it’s stem to remove it. So you’ll need a new one if you do remove it, that’s why we need the E-Nr see 😉
The “timer” on the heater is a clockwork diverter valve for top and bottom spray arms.
I can only assume the grey box you refer to is the aquastop ❓
The “little round box” as you call it again without E-Nr I can only guess it’s the impellor jug (flow meter) replaces the old pressure chamber.
April 2, 2008 at 6:33 pm #247531fasetester
martin wont be able to get the ern number i know i should have taken the model no ect down. by the time i got the dishwasher out pipes in behind back of unit then the main water feed jammed up the back with that big gray box. the only time i saw one of these boxes what are the one way valves or what. on hobart commercial dishwashers when the owner say smoke the did not want to repair it. i was looking the info for my own knowledge for again. are these part not common to a lot of dishwashers thanks fasetester 🙂
April 2, 2008 at 6:38 pm #247532deltra
aquastop will need to be reset. 😉 unscrewing it from the pipe to release pressure usually works 🙂 (turn water off first)
April 3, 2008 at 12:31 pm #247533fasetester
thanks martin and super fix for trying to help i know its not easy with out the enr number . deltra i did disconnect the water hose under the sink there is no connection at the back the hose goes in throught the back then connect to the the impellor jug. from their a blue hose is connected to the iwms deltra what is the gray box for on the main water feed under the sink it looks like a motorised valve on a heating system and what does it do thanks fasetester.
April 3, 2008 at 12:39 pm #247534cornwell40
:rotfl:
Fase, you had onions for dinner…..you keep repeating.
TCApril 3, 2008 at 12:48 pm #247535fasetester
kept saying error cornwell can not send message how do i do away with all the post bar one fasetester.
April 3, 2008 at 12:55 pm #247536Martin
fasetester wrote:what is the gray box for on the main water feed under the sink it looks like a motorised valve on a heating system without the wires and what does it do 😳 thanks fasetester.
It’s the inlet/safety valve fase. (Common on many BSH and Miele Dishwashers these days). The inlet solenoid and water block system are contained within that grey cover.
Deltra referred to it as an “Aquastop” (same thing) and as he mentioned, if your machine won’t fill it’s worth at least bleeding the aquastop first to see if that cures your problem? That means turning the stopcock off, unscrewing the brass coupling, refitting it immediately and turning the stopcock back on again. If that fails to resolve the problem then the impellor jug could be at fault?
Please give us that Enr number please so we get the full picture of what machine we are all trying to fix here. 😉
April 3, 2008 at 12:57 pm #247537Martin
fasetester wrote:kept saying error cornwell can not send message how do i do away with all the post bar one fasetester.
Leave it to me fase on that 😉
April 3, 2008 at 1:58 pm #247538fasetester
so the solenoide and aquastop is inside the gray cover martin instead of at the back of the dishwasher how does it work as there is no electrical connection and how can the be tested or are the a sealed unit thanks fasetester.
