Bosch dishwasher
  • #43826
    robbra
    SGS53C02GB15
    Cycling pump runs but no fill. Flow meter is o/c so would this be the symptom? This model has the removable bottom panel and what looks like a timer motor on the heater housing.
    Rob
    #278719
    aqualectric
    Re: Bosch dishwasher
    Flow meter (or impellor jug) is a common fault on these removable baseplate machines. Part number 424099 @ £13.08 (P+P and VAT extra) from BSH site. £11.93 + VAT from Connect.
    The clock motor on the heater manifold operates the ‘bias valve’ that regulates water flow to the rotors. As the motor turns the valve, the top rotor is fed full bore with low pressure to the bottom rotor. Then the valve turns and the bottom rotor is fed full bore with a diminished supply to the top rotor and so on. 😉
    HTH,
    Steve.
    #278720
    robbra
    Thanks Steve,
    Had this fault with impellor jug pcb faulty before on a different Bosch where it would fill then empty continuously. but this is not filling and no power to the valve. Will order the part .
    Rob
    #278721
    If that cures it keep the old one and stick a new reed switch in it. Penguin posted something about this a few weeks ago and gave the Maplin part no. for the reed switch.
    Mike.
