bosch dishwasher
  • #54913
    der
    bosch exxcel maxx freedom performance dishwasher5600041012/02337/02.51
    how to remove base of machine in order to access leaking hose near front please. thanks
    #321368
    Re: bosch dishwasher
    Have you got a model number ?
    #321369
    silverbroom
    If this is the clear plastic type hose coming from the sump then you can do the job by removing the kick plate and the left hand side panel.
    Bosch part number 298556 or from Connect.
    silverbroom
    #321370
    der
    iadom wrote:Have you got a model number ?
    SGS53A02GB/38
    cheers
    #321371
    Silverbroom is correct. Remove front plinth, screw each side and yank it off, remove plate behind it to access hose on that model.
    #321372
    der
    Ok Thanks for your help I ll try that !
    #321373
    clivejameson
    Are you sure it’s leaking and not overflowing from the float chamber?
    #321374
    I’m with Clive on that, forget about taking front panel off but whip the lid and both side panels off instead and check whilst it’s running for leaks. The usual suspects are the float/pressure chamber, main motor seals, water point device and salt container gasket.
