Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch dishwasher
- This topic has 8 replies, 6 voices, and was last updated 13 years, 5 months ago by
domesticbliss.
November 9, 2012 at 4:14 pm #72440
domesticbliss
ParticipantHi, working on a SG145E15GB/31 which fills then empties, fills and empties constantly with the check water light coming on also.
Havn`t worked on this type before that doesn`t use the float/ micro switch system or diaphram shut off..leaning towards either the impeller jug or the water softner unit clogged up..
any other ideas would be greatly appreciated.
PaulNovember 9, 2012 at 4:57 pm #384527Twoten
ParticipantRe: Bosch dishwasher
Change the impeller jug, that should solve your problem.
November 23, 2012 at 9:50 am #384528domesticbliss
Thanks for that, rectified the problem.
MANY thanks
PaulNovember 23, 2012 at 5:59 pm #384529martinm
Just curious what exactly is the impellor “JUG”?
November 23, 2012 at 7:12 pm #384530Martin
martinm wrote:Just curious what exactly is the impellor “JUG”?
A rotary magnetic reed switch. As the Impellor rotates the reed switch opens and closes creating pulses. The control module counts the pulses to regulate the amount of water passing through the inlet valve.The plastic Impellor wheel is subject to a lot of friction wear and the major cause of the device failing.
Why Siemens/Bosch named it Impellor jug is something of a mystery lost in translation and over there it’s called a Flügelrad, so I’ll leave you to finger that out. 😕
November 23, 2012 at 10:52 pm #384531nomadPaul
Martin wrote:
……. over there it’s called a Flügelrad, so I’ll leave you to finger that out.
😯 😯 😯 8)
November 24, 2012 at 9:13 am #384532Martin
Ooooops !!! 😳
These darned iPad predictive text thingys cause finger trouble, that proves it!
November 24, 2012 at 4:08 pm #384533nomadPaul
Martin wrote:Ooooops !!! 😳
😆 😆 😆 :boops:November 24, 2012 at 6:51 pm #384534Galway
Reed switch can be replaced easily on these without having to replace impellar jug completely if you keep a few in the van and you wont need to order one and call back 😀
