Bosch dishwasher
  • #72908
    loopey
    sgs43c02gb
    fd 8306670156
    dishwasher goes though to the end with no heat on all progs
    heater matrix changed PCB changed no broken wires .
    checked all connectors , could it be a faulty PCB as there is
    no live to the heater any were … help
    any one have a wiring diagram for it
    thanks in advance phil ..
    #385928
    Re: Bosch dishwasher
    You’ve replaced both the heater AND the PCB?……..wow that is one costly job for sure. 😯
    Yet it completes the cycle?…….very odd. 😕
    Non of this makes any sense I must say so perhaps I should instead ask if it washes and drains as normal AND if the diverter valve is working OK? Also did you configure the PCB as per the instructions? Finally, can you give me the FULL Enr number of the machine. 😉
    #385929
    loopey
    yes configured pcb ok , only £60+ from qualtex , heater matrix was a stock item
    i requierd lol , fitted it to see if made any difference.
    yes completes the cycle i no very odd, no fault code either
    filling and emptying ok , diverter working fine can here the difference in the wash
    just no heat , carnt get a live to any part of the heater matrix so i think faulty pcb.
    enr 10306160231184320156
    #385930
    loopey wrote:enr 10306160231184320156
    Never mind on the Enr number (that’s not it by the way) it is either SG43C02GB/35 or SGS43C02GB/43. They have different PCB’s, hence my asking the question. 😐
    You should at least get a live feed to the heater and the PCB supplies the neutral return, so that is very odd. Also the PCB would not complete the cycle with no heat as it relies on the NTC in order to progress the heat phase and the rinse aid dispenser heater solenoid/heater coil thingy…..very odd indeed. So yes the PCB cannot be ruled out which brings me back to the Enr no and the part no of the PCB fitted?
    I wonder what the original fault was too? 😕
    #385931
    loopey
    original fault was the same as now going through with out heating , its driving me nuts .
    will get back to you with the enr number again when i get in work to moz
    this dishwasher is 4 to5 years old , customer says ony uses it 3 to 4 times a year partys chrimbo it is spotless i must say . thanks for the help so far .
    phil
    #385932
    loopey
    sgs43c02gb/35
