Bosch dishwasher
  • #89428
    kaibart
    Having problems with this bosch dishwasher not draining
    Sgs53c12uk/01 fd 8611 08469 it has a waste extension kit fitted this has been checked all ok check pump for resistance was low so replaced the pump but had a call saying it’s not emptying any ideas? I’m not the best on bosch dishwasher’s 🙁
    #441360
    Re: Bosch dishwasher
    Depends what you mean by waste extension kit? The drain pump output is weak at best so extension hoses can be an issue as you know. The non return valve can restrict the flow so that’s worth double checking.
