that is an odd one
there is no reason i can think of why one wash drains but the other doesnt
on a lot of later machines the pump is used as a sensor.
When draining the current is higher going to the pump under load but once it draw air it drops and the board senses this to determine if its empty, worn pumps can have a higher current due to fiction which can fool the board into thinking its not empty but your left with water in and i assume no fault codes
you dont state an Enr so i dont know what system we are talking about
