Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch dishwasher aquastop diagnostics
- This topic has 7 replies, 3 voices, and was last updated 6 years, 7 months ago by
petric3.
August 17, 2019 at 6:48 pm #96281
petric3
ParticipantIm getting the water tap symbol error and have tried to clean filters (at water pump insider dishwasher, wall water tap and acquastop), checked the hose, etc. I actually observed that water matrix fills up pretty slowly. The manual says that there should be at least 9 liters water per minute from wall water tap, which I measured and it is more than that. However, the water flow from the hose with the aquastop is only about 2 liter per minute (measured at hose outlet before water matrix). The aquastop also gives like 50Hz-type whirring sound. Does this mean that acquastop is problematic or does acquastop suppose to slow the water flow into the dishwasher?
August 17, 2019 at 10:52 pm #462884electrofix
Moderatorwhat model machine have you got
Enr and Fd number
August 18, 2019 at 1:18 pm #462885petric3
ParticipantENR: SGV55M63EU/01
FD: 8707Tnx, Rok
August 18, 2019 at 2:38 pm #462886electrofix
Moderatorcheck the item here is clean and not full of gunge
if yes switch dishwasher on, start programme, open door and add 2 pans of water, then close door and see what happens, you could add a bit more but do it in stages. the idea is to see if unit functions once enough water has entered
August 18, 2019 at 3:04 pm #462887petric3
ParticipantThanks Dave, I have also cleaned that part as well as the water matrix tank – the passages are clean and water flows well through it. When I turn on the machine, after the drainage is finished, water filling starts and I observed that the water matrix fills slowely (in comparison on what I saw on youtube as a normal filling up) which led me to the idea to check the inlet hose (with aquastop attached). So what I observed is that there is over 10liter/min of water into hose with aquastop but less than 2liters/min from the hose, so I started to wander if aquastop is the problem coz the hose itself has no gunde observed. Any thoughts?
August 18, 2019 at 6:21 pm #462888electrofix
Moderatoroh yes they do go faulty
before you jump in did you check the water filter in the end of the hose by the tap ?
luckily with the gen valve being £90 there is a non gen alternative
https://shop.ukwhitegoods.co.uk/compatible-aquastop-fill-valve
August 18, 2019 at 6:32 pm #462889petric3
ParticipantTahnks for the reminder, I did check the tap filter and cleaned it.
Considering the dishwasher’s age, non gen alternative soungs great, thank you very much.
Rok
August 19, 2019 at 12:37 pm #462890winecooler5
ParticipantWhich model did you bring?
