bosch dishwasher check water light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher check water light
Viewing 15 posts - 1 through 15 (of 15 total)
  • #102832
    suedehead1
    Bosch dishwasher SMS40T32UK/45. the check water light comes on almost immediately its switched on,
    no water in the base. it does nothing no fill no empty no noise at all. its a free standing unit.
    any ideas?
    #490664
    look up bosch part no
    646776
    suedehead1
    hi Dave, i have had a look at that part, never seen one before do you think thats the problem
    #490666
    suedehead1
    is that part number correct? seems to be a dryer part
    #490667
    me having a senior moment and posted on the wrong page sorry
    will delete my post above
    suedehead1
    no problem
    #490669
    Kentish
    Drain pump.
    That would be my first point to look at.
    #490670
    ali_g12
    Kentish wrote:Drain pump.
    +1.
    Without any diagnostic facility it’s difficult to know where to start with the Bosch machine without a digital display. Perhaps a Bosch engineer could tell us what they’d do?
    I’d have a look at the regen valve as I seem to remember similar symptoms if that goes – E19 I think.
    #490671
    so the check water light comes on as soon as you turn on, does not even wait till you try and set a programme ? correct ?
    is light on or flashing ?
    suedehead1
    the light is flashing
    #490673
    ok so that means its not a water fault
    if the light was not flashing that would be a water fill fault
    the fact its flashing means it can be anything else which is not a lot of help as its not a specific fault code
    suedehead1
    Thanks i decided to tell customer to buy a new one,
    #490675
    twicknix
    I have similar experience with this dishwasher and it is a mystery.
    I find that isolating from the mains sometimes solves this or even replacing the drain pump and flow meter reed. I don’t know if the heat exchanger drain valve is the cause so it is a case of parts bingo. One of them will cure it.
    #490676
    neon_3SP_glow
    electrofix wrote: ok so that means its not a water fault
    Is this flashing/not flashing, water or not water related across all Bosch D/W’s – never knew and seems very helpful.
    What annoys me most on the Bosch D/W is the random leaks which cause anti flood every few months, but NEVER appear when I test the units.
    #490677
    its quite often the leaking polynex bases
