Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch dishwasher does not drain
- This topic has 6 replies, 4 voices, and was last updated 16 years, 10 months ago by
donmaico.
June 7, 2009 at 10:58 am #46263
donmaico
ParticipantI have a Bosch Exxcel Max which unfortunately seems blocked, water lying at the bottom of the machine.I have no manual to find out where and what needs looking at so i was wondering where I can download one,I looked at Bosch own website but get no hits from Exxcel and Maxx.I also dont appear to have a model number anywhere.Could someone advise me please? Thank you
June 7, 2009 at 11:25 am #288736Penguin45
ParticipantRe: Bosch dishwasher does not drain
Model number is etched into the top edge of the inner door, next to the door latch. Typically will read ‘SGS—-GB/–‘. Enter that on http://www.bshappliancecare.com and you can call up the diagrams for your machine, or download user books.
You can access most Bosch drain pumps through a cover plate at the 9 o’clock position in the sump, under the filters. Bail out what you can first.
June 7, 2009 at 12:36 pm #288737donmaico
Penguin45 wrote:Model number is etched into the top edge of the inner door, next to the door latch. Typically will read ‘SGS—-GB/–‘. Enter that on http://www.bshappliancecare.com and you can call up the diagrams for your machine, or download user books.
its verY faint but it seems to read SGS43EO2GB/45
MANY THANKS
NB .I cut and paste that model number but got no return.It asks for an E number, whatever that is 😕
June 7, 2009 at 12:45 pm #288738donmaico
Oh I see the E number is the model number, now the nearest i can find to it is SGS43EO2GB/43.Would this be ok do you think?
June 7, 2009 at 1:40 pm #288739nomadPaul
Participantyes , that is the ENr number . OK , 1st things 1st . On the front of the appliance , there should be a ‘reset’ sign under the buttons . With the machine switched on and door closed , press the two buttons indicated by the reset sign….your appliance should switch to ‘end’ or ‘0’ minutes left dependant on model. Give it a couple of seconds and the pump should fire up ….you should hear it running , attempting to pump out.
There are now 2 things to check.
1. If you can’t hear the pump fire up then this would normally indicate a pump blockage. Remove as much water as possible from the appliance and in the bottom of the sump , after the filters have been removed , you will see a single screw holding a white plate . Remove this screw (Torx 20) and the white cover. This will give you access to the pump impellor allowing you to check for a foreign object. IMPORTANT POINT – Make sure you replace the cover and screw before testing as the pump won’t work without these in place.
2. If you can hear the pump running but its not draining then this would indicate a blockage in a hose/connection. Check your drain hose , especially if its connected directly to your sink waste .
Hope this helps
PLEASE UNPLUG APPLIANCE IF YOU INTEND TO CHECK PUMP
November 23, 2009 at 2:27 pm #288740donmaico
ParticipantnomadPaul wrote:yes , that is the ENr number . OK , 1st things 1st . On the front of the appliance , there should be a ‘reset’ sign under the buttons . With the machine switched on and door closed , press the two buttons indicated by the reset sign….your appliance should switch to ‘end’ or ‘0’ minutes left dependant on model. Give it a couple of seconds and the pump should fire up ….you should hear it running , attempting to pump out.
Hope this helps
sorry for the delay in replying,As it turned out it was a blocked pump which was easily cleaned , thank you
November 24, 2009 at 2:00 am #288741gandh1
Participantdonmaico wrote:sorry for the delay in replying,As it turned out it was a blocked pump which was easily cleaned , thank you
❗ A dishwasher is for Washing. to prevent future blockages always scrape plates off into the bin to remove all large leftovers, then rinse plates off prior to dishwashing – you wouldnt put a gravy/sauce-laden plate into a fresly run washing up bowl, so dont do it to the poor d/w! ❗
PS make sure you regularly check the filter, apprix every month if used daily!
