Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Dishwasher Door Latch
- This topic has 6 replies, 6 voices, and was last updated 21 years, 1 month ago by
Rod.
March 9, 2005 at 11:02 pm #8382
Rod
ParticipantHello,
Can anyone advise on a doorlatch that will not close.
I have removed the front panel and can activate manually the latch but it needs significant force to close it. It almost seems as though the spring has compressed too far and does not provide enough force to force overthe latch into the plate…is there ant adjustment what do I replace?
Regards
RodMarch 9, 2005 at 11:59 pm #128277gegsy
ParticipantRe: Bosch Dishwasher Door Latch
This is may sound stupid, but only time I had problem with bosch door latch is when basket was in wrong way.
Model would help also as latches vary
March 10, 2005 at 10:18 am #128278clivejameson
Rod…the latches are not adjustable themselves, if there is a problem with it then it needs replacing as an assembly. Sometimes mis-alignment between door and cabinet can cause problems too.
If you post the model number (top edge of door or underneath front edge of worktop) then more specific advice might can be given.March 10, 2005 at 1:25 pm #128279admin
KeymasterRe: Bosch Dishwasher Door Latch
Hello,
The model No is – S5N27B – SMS4472GB/20
THere is definetly nothing restricting the doors from closing ie: tray.
It appears that the ‘Latch key’ on the body of the D/Washer, does not push against the latch ‘jaws’ sufficiently . This movement which is activated like a cam forces the jaws to close and hold the door in place…as clear as mud!!!
Any ideas???
March 10, 2005 at 1:33 pm #128280Martin
You will find that the Door Latch Assembly (Part No: 056218) has broken and will need replacing. Available directly from Bosch http://www.bshappliancecare.co.uk
or by emailing spares@ukwhitegoods.co.uk (do copy & paste this posting with your message though)
March 10, 2005 at 5:15 pm #128281admin
…but do just check first that the metal latch on the cabinet hasn’t simply moved/come loose!
March 10, 2005 at 6:41 pm #128282BSH-MAN
Anonymous wrote:…but do just check first that the metal latch on the cabinet hasn’t simply moved/come loose!
:lesson: Wise words 🙂
