Got a bosch WAE244S0GB that is beginning to get the better of me.
It simply will not empty.. Checked the hoses, and they are clean. Removed the waste pump and checked the sump.. All clear. Checked the one way check valve, and that functions correctly.
Every time the machine is told to empty I get error 25.
I’ve removed the pump and turned on Pressed and held the start button to empty only the pump runs for the minute that it’s supposed to and the machine ends the cycle properly.
I fit the pump add a little water then press the power button to empty, the pumps then runs for 1/2 a second then waits a seconds..then repeats this several times until I get the error 25 message.
Anyone get any ideas? Lastly, there is plenty of torque in the pump when it runs.
Any help greatly appreciated.
