bosch dishwasher fails to start
Home Forums Public Support Forums Help And Support Dishwasher Help Forum bosch dishwasher fails to start
  • #52803
    sarg3
    Hi there, i have a bosch sg15305gb/11 dishwasher which has just stopped working. When turned on none of the buttons will start machine, but they do light up to say they have been selected. The only one that does something is the intensive wash. When that one is pressed, the display shows Zero and it sounds like its trying to pump out water. (of course there isnt any to remove). Any ideas chaps??
    Thanks in advance
    Mark
    #313197
    nomadPaul
    If ‘0’ has come up in the display and the machine is pumping out , this would indicate the ‘re-set’ function has been selected. However , this is normally only achieved by holding down two buttons at any one time. Therefore , the first thing i would do is check that none of the other buttons are stuck or wedged down
    #313198
    sarg3
    Re: bosch dishwasher fails to start
    You may well be onto something there, just had another look and the 3rd button does not light up when pressed. But when the first, intensive button is pressed the 3rd buttons lamp illuminates and the display goes to zero and pumps out. None of the buttons appears stuck, and even the 3rd button clicks when pressed.
    I take it just turning machine off would cancel the reset procedure? Perhaps the next step is to test the switches. i.e take cover off and check for voltage passing through open then closed switch? What do you think?
    Thanks for your fast reply!
    Mark
    #313199
    nomadPaul
    we don’t condone live testing Mark…and it would make no difference anyway as the buttons are all part of a control module .
    Its difficult to have a definite answer with your fault and as the control module is approx £120:00 , i wouldn’t like to say that the module is def at fault.
    Once you get into the reset , you have to switch off the machine , open the door , close it and then press on. This should now be back to a point where you can select a cycle and start a new one.
    You’ll need a closer look at the control module to see if there’s any damage there
    POWER OFF IF INVESTIGATING
    #313200
    sarg3
    Thanks for that, i wont be live testing, i’ll put on an ohms meter and test it. Thanks very much, i’ll report back my findings.
    Mark
