Bosch Dishwasher fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher fault
  • #30014
    RH5hz
    Hi All,
    I’m new to the forum , and hoping I can get some help.
    I have a integrated Bosch dishwasher, Ser No:SH4313GB/13.
    It has a fault, which prevents it filling with water, at the start of its cycle. The dishwasher emmits a humming noise on start up, I cannot hear any water filling. This occurs on all programs.
    I have checked the following:
    -Water pressure ok to the Aquastop
    -Have disconnected(mechanically) the Aquastop at the valve, switched off diswasher and reconnected.
    -Have reset dishwasher by pressing 2 buttons on panel.
    The aquastop is sealed and I cant get into it to fault find, could it be this? or could be a fault with the dishwasher itself?
    Being an integrated unit. I want to make sure before I take half the kitchen apart. 😉
    Thanks in advance for any help with this.
    #225518
    Re: Bosch Dishwasher fault
    The baseplate likely as not is flooded and needs draining. Then careful investigations as to where the leak is coming from. 😉
    If you need a hand to check it out thec click on the link below for a local engineer. 🙂
    #225519
    RH5hz
    Martin,
    Thanks for the speedy reply, no engineers in my area (west Sussex). Can you give me an idea of how to drain the baseplate?
    ie:does the dishwasher need removing or can I do this insitu?
    Thanks 8)
