Bosch dishwasher fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher fault
  • #89337
    annesmall
    Hi, I have a Bosch Avantixx SMS40A0 dishwasher and it isn’t starting. Unfortunately it isn’t giving me an error code, it is just flashing with the cycle time, but not starting. I have tried doing the test cycle and get an E00 code, which i think means there is no error detected, but it still won’t work. I have had it for 3 years and had no problems until now.
    #441076
    Re: Bosch dishwasher fault
    Possibly the door is not shutting properly and the door sensor thinks the door still open, maybe?
    #441077
    annesmall
    Oh, maybe. Is there any way that could be tested?
    #441078
    annesmall wrote:Oh, maybe. Is there any way that could be tested?
    Well, carefully double-check that the door isn’t obstructed in any way (i e Top basket not located properly or machine not standing on a level floor surface)
    With a little light pressure on the control panel check to see if it starts then. (The door sensor is indeed very sensitive magnet type)
    #441079
    annesmall
    Solved! Thank you very much. I think i’ll need to get someone out to look at it, but at least i know what the problem is.
