Bosch Dishwasher – fill never completes (Starts to drain)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher – fill never completes (Starts to drain)
  • #66995
    TomF
    Diswasher Bosch Model ‘Electronic Management’ E-Nr SGS43T02GB/06
    The outlet pumps intermittently when the machine is full (or nearly full) so the fill never completes.
    I suspect there is a problem with a ‘fill level’ sensor, and the inlet valve is not being shut off, but not sure if I am right, or where to look.
    Any help appreciated.
    #365950
    QUICK FIX
    Re: Bosch Dishwasher – fill never completes (Starts to drain
    impellor jug had same fault last week
    #365951
    TomF
    Thanks for getting back.
    I can’t find a user called impellor jug?
    Sorry if I am being dozy!
    #365952
    TomF wrote:I can’t find a user called impellor jug?
    What QUICK FIX hasn’t realised is that your machine doesn’t have an Impellor Jug anyway. The problem could simply be the magnetic float sensor under the drain filter being gunged up?
    #365953
    TomF
    Thanks Martin,
    I emptied the water out of the machine last night, and filled it with warm water (poured directly into the drain filter well).
    It completed an unloaded wash, then washed the original load of dishes twice, with no problem.
    I just read your post, and looked at the magnetic float sensor.
    It was a little gunged, but not bad. I probably washed it last night, when I poured warm water into that very area, with the filter out!
    I have now cleaned it the float area, and another wash has started successfully.
    My gut feeling is that your diagnostics was right, and, fingers crossed, the problem is cleared.
    Thank you for taking the time. You too QUICK FIX
    #365954
    QUICK FIX
    :boops:
    #365955
    TomF
    No Problem QUICK FIX, It’s impossible to know every model!
    It looks fixed now, and thats what’s important.
    Many thanks
