Bosch SGS43T72UK/30 with normal constant fill/drain problem.
New impeller jug fitted.
Now fills, pumps out once then fills and circ pump starts as it should. However fill valve is still actuated so fill / drain cycle continues but with machine washing and heating as normal !
If program is cancelled then just the drain pump functions so cant be a shorted PCB feed to the valve.
Any suggestions
Is the impellor jug the right way round, i replaced one thought it was okay got a call still wasnt right went back and fitted another put it in the other way and it worked after that, either that or the 1st one was faulty.
