Re: Bosch dishwasher fills but does not start
No circulation = no pressure on the diaphragm switch in the heater = no heat = no progress through the programme.
Remove plug, lid and right hand side panel to access the motor, and check whether or not it is free to turn – there should be light resistance. If it is free, check whether or not you can hear a humming noise when the motor is activated. If it hums, it may well need the start/run capacitor replacing. If no hum either the motor or the pcb will be at fault.
