You haven’t given us enough information here I’m afraid 🙁
What is the model number? Having cleared up the mess it has left, have you checked that the filter is clear? Is the drain outlet blocked?Does it work at all now? Has the fuse blown?
The model si SGS43A32. I have checked the filter and the outlet drain. There is power and as soon as you switch it on the pump is running. It was doing this at 5am this morning. Must have been running all night. From the dishes it looks like it had only done the wash cycle. I have tried the reset button to cancel the program but the pump still runs and it doesn’t matter whether you put it on a wash or a rinse.
Thanks for that, now I realise what the problem is with your machine 8) It is simply blocked, but it will need an engineer in to do that for you AND is not an expensive thing to sort 🙂
Simply go to “Repairs@” and fill in the drop down forms to get a local engineer to quote you for fixing it……..EASY!
