Bosch Dishwasher full of water at end of cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher full of water at end of cycle
  • #25495
    Brookwood100
    Our 9 year old Bosch (very simple model with only one temperature setting) has stopped pumping water out at the end of the programme.
    We have checked the hose and the pump and cannot find any blockage.
    Anybody got any more suggetions? Anybody got any diagrams of how it comes apart?
    #206099
    Re: Bosch Dishwasher full of water at end of cycle
    You haven’t given us the model number, so what follows is guess work……..
    Does the pump actually run? You should be able to hear it whirring away if it does. If it doesn’t, you need to check with a test meter for a circuit through the pump. The older machines were prone to wiring failures, especially in the door, where the wires pivot under the machine. Does the pump look rusty? The older machines used a metal bodied pump – if the seal goes, water gets into the bearing and seizes the pump eventually. If you can hear the pump running, there must be a blockage somewhere. If it’s coupled on to the sink, that’s the first place to look.
    You can find exploded diagrams of the machine on http://www.bshappliancecare.com , providing you can insert the full model reference. Use “Bosch”, then “Spares” the “Quickfinder” to view.
    Power off, for anything other than observation, please.
    Brookwood100
    We found a blockage where the outlet joins the sink outlet, so hopefully clearing this will have cured the problem. Thanks for your advice.
