bosch dishwasher heat circ pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher heat circ pump
  • #86045
    mikehha
    having fitted three of these in the last month I have just been back to one of them which has the heater open circuit is there a problem with these or have I just been unlucky.( me thinks that these are not going to be to reliable).
    #430151
    Re: bosch dishwasher heat circ pump
    Loads of posts complaining about these heat pumps. Bosch ‘Scheiße’ 🙁
    #430152
    nomadPaul
    Are you finding the heat pumps sitting in water ? The problem is as much to do with leaks from the tanks as much as the heat pumps themselves on a lot of occasions. The tanks leak water which accumulates under the heat pump which then short out.
    #430153
    mikehha
    I think you are right there was water in the bottom because the tub/tank was leaking
