Hi.
Because some of the Bosch dishwasher heat pumps are now getting very expensive I thought I would try to fit just the heating element which is now supplied by Connect.
Firstly it’s a right pain trying to separate the heater housing from the motor without damaging the retaining lugs.
Then you’ve got pull the element out of the body which is a very tight fit.
Then the fun begins, because it’s virtually impossible to locate the new element.
I’ve tried everything without any success,I’ve even tried refitted the old one but the tolerance is just too tight.
I’ve now given up and will be returning said item for a refund.
Any of you guys had any success with these elements?
Cheers.
Noel.
