Hi, I don’t normally do dishwashers, but I have a Bosch to look at on Wednesday (I believe it’s a slimline). The complaint is that it is not draining and there is a small amount of water on the floor.
Any tips of what I should be looking for would be greatly appreciated.
Merv
has a sealed base so unusual to leave water on the floor unless its a blocked pump and way overfilled in which case most of the electrical parts will be underwater. Some models you can clear the drain pump from inside after removing the filter while some others is a pump off job.
