Bosch dishwasher ‘Hydro sensors’ and 1 fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch dishwasher ‘Hydro sensors’ and 1 fault code
  • #8621
    Ray9500
    Does anyone else have trouble with these?
    Number 1 shows in display at the end of the cycle, and according to bosch info it’s a Hydrosensor fault. I have now changed two of these and it doesn’t cure the fault 😕
    Bosch technical told the customer it was because there was not enough water in the machine so not activating the heater 🙄
    Both dishwashers have heated ok but the customer now doubts my diagnosis as bosch technical can’t be wrong , can they 👿
    Ray
    #129673
    Re: Bosch dishwasher ‘Hydro sensors’ and 1 fault code
    Ray9500 wrote:Both dishwashers have heated ok but the customer now doubts my diagnosis as bosch technical can’t be wrong , can they 👿
    Have you got a model number you can give us Ray?
    I believe these ‘hydro sensors’ are tacked onto the heater box anyway if I’m not mistaken? I would imagine Bosch engineers would replace the whole heater unit with sensor unit and be done especially if its crudded up with limescale thru not using salt?
    Ray9500
    They are pretty straightforward to change and on the ones i’ve done, the heater boxes have been spotless.
    anyway…don’t like changing heater units on these 😀
    I shall dig out the model number for more clarity.
    Regards
    Ray
    #129675
    Ray9500 wrote:the heater boxes have been spotless.
    anyway
    Not sure how you would know that Ray if you haven’t changed it 😕
    Ray9500 wrote:…don’t like changing heater units on these 😀
    As the fault is associated in this area it really would be your favourite option though, in spite of the fact its a fag taking the tank off and stuff 🙁
    Ray9500
    once you take the sensor out, you can have a peek with a torch.
    Personally, i just use the ‘Force”….. 😀
    Ray
