bosch dishwasher just gone dead on me
Home Forums Public Support Forums Help And Support Dishwasher Help Forum bosch dishwasher just gone dead on me
  • #35028
    somebodyhelpme
    HI CAN ANYONE HELP ME WITH MY DISHWASHER??
    ITS A BOSCH FULL SIZE INTERGRATED UNIT MODEL NO. SGV43A03GB/44PRODUCTION NO:8309
    LOADED UP AS NORMAL WENT TO SWITCH ON AND FOUND ITS DEAD.SO CHECKED FUSED SPUR AND CONNECTIONS,ALL OK.
    IS IT LIKELY TO BE A C/B FRIED?? NOT HAD MANY DEALINGS WITH WHITE GOODS MORE USED TO FIXING AIRCRAFT SO ANY TIPS IN THE RIGHT DIRECTION WOULD BE GREAT 💡 ..
    THANKING YOU IN ADVANCE
    #244863
    helo_75
    possibly, it could be the mains filter
    its at the back, where the cable goes in the machine
    plug out if investigating
    after that, its on/off switch then pcb
    hope this helps
    #244864
    somebodyhelpme
    Re: bosch dishwasher just gone dead on me
    MAINS FILTER YOU THINK..IS THAT A SEALED UNIT I JUST METER OUT??
    I ASSUME THEY BURN OUT SOMETIMES??
    #244865
    helo_75
    depends on the model
    burn out is a term i dont like, yes they go o/c, and it isnt common, worth checking before you go down the expensive pcb route
    if your confident of testing at board level (plug out of course) it may be just a dry joint
    #244866
    somebodyhelpme
    thanks helo will check it out. worse case how much do the pcb board cost on average?? as its nearly 5 year old now in which case may be aswell to renew if its going to cost a lot.
    #244867
    gegsy
    somebodyhelpme wrote:……………worse case how much do the pcb board cost on average??
    Retails around £80+ Vat etc, p/no 492685 and if required and is available form the shop@ link on the left 😉
    If it was me I would find where the appliance plugs into, ie the socket from the spur and examine the socket and the plugtop for any signs of overheating then move inwards as per helo 😀
    Power off first :plug:
    Kentish
    Often find over tightening of the top left decor door fixing screw can cause the on-off button to bind and not fully operate the switch. Slackening this off slightly would cure that.
