Bosch Dishwasher Keeps Filling with water at end of cycle.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher Keeps Filling with water at end of cycle.
  • #100150
    Helicon
    Bosch Dishwasher SGV43EO3GB/22 will do the wash cycle ok. But after the beep sound at the end the water start to fill again. The water has to be turned off or the house would be flooded. I was very lucky to catch this on one night before going to bed. The water had just started to drip out the door. The next day after making sure everything was dry I put it in rinse. It was the same again everything worked ok to the end. Then after the beep it started to fill with water. This even happens with the dishwasher switched off and the door open. The only way to stop it is to turn the water off. The only other problem in 14 years was a door switch and spring. Could it be the impeller jug or solenoid valve? Maybe it’s time for a new dishwasher. I would appreciate any help thanks. [h=1][/h] [h=1][/h]
    #479474
    if the water keeps flowing after you remove the plug then the valve is faulty
    Helicon
    Thanks for the reply. I can’t find a water valve for model number SGV43EO3GB/22 on ukwhitegoods.co.uk. The photo of the valve on the site looks the same but no model number match. So can I rule out the impeller jug as the problem or even part of the problem? I don’t mind getting both. But the washer is 14 years old so is it going to be one thing after another from now on in? Thanks again for the reply.
    #479476
    try
    https://shop.ukwhitegoods.co.uk/299756-dishwasher-aquastop-fill-hose
    getting bosch part no’s is easy
    you go here
    https://www.bosch-home.co.uk/customer-service/spare-parts-search
    put in your Enr then look for the part no
