Bosch dishwasher leaking
  • #91500
    dunston
    Bosch dishwasher model SMI50CO6GB/03 is leaking at the rear seam between the stainless steel and plastic wash chamber.
    The rear of the dishwasher looks like it has deformed.
    We have seen a couple of Bosch dishwashers leaking in the same place and both had a blocked upper spray arm.
    Anyone had this fault? and is a blocked spray arm causing the leak?
    #448333
    Re: Bosch dishwasher leaking
    dunston wrote:Anyone had this fault?
    Dozens of posts on the subject. Use ‘search’ to peruse at your leisure.
    Basically the plastic tub warps and leaks on only the very long hot cycles. Sealant can be the only solution (pardon the pun) 😉
    Go SEARCH for others comments on the subject 😀
    #448334
    dunston
    Thanks Martin. Tried to search, cannot find the posts. Can you direct or what key words to use?
    #448335
    dunston wrote:Can you direct or what key words to use?
    ‘Plastic tub leak’
