Bosch Dishwasher No Water intake
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher No Water intake
  • #87838
    Taff543489
    On this machine when a program is selected the machine drains as normal the instead of filling with water the main wash pump kicks in. I think this could be a problem with the control module!! can any one confirm this?
    #436148
    Re: Bosch Dishwasher No Water intake
    Model number Taff, model number? I only do mind reading on a Whit Monday. 😛
    #436149
    Taff543489
    Sorry SGS43EO8GB/43
    #436150
    Taff543489 wrote:Sorry SGS43EO8GB/43
    No worries Taff.
    Pressure chamber microswitch may be the issue here. The machine thinks it’s full of water and the only way it would know that is once the pressure switch microswitch has been activated. Have you checked and cleaned out the pressure switch area and transfer pipe?
    #436151
    Taff543489
    Yes done that and checked that the micro switch is working/ I even changed the chamber assy that has the over fill float in it.
    #436152
    johnnyj
    Had one doing the same recentlty, did all the usual cleaned the transfer pipe fitted a pressure chamber, had to change the module.
    #436153
    Taff543489
    Thanks for all the replies it looks like a new module.
    #436154
    Martin114
    I should check with the FD number if this model is part of the recall for the module.
