Bosch Dishwasher not draining
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher not draining
  • #15201
    Twoten
    This topic looked easy didn’t it 😆
    Sorry but the pump runs and drains, no blockages.
    Operate the anti-flood switch and it drains.
    Problem is when you start the program or cancel the pump doesn’t run.
    I can’t find any breaks in the loom or dry solder joints on the PCB.
    I haven’t come across this before, so by a process of elimination can only assume it’s the control unit.
    Has anyone come across this before?
    #162594
    Re: Bosch Dishwasher not draining
    Twoten wrote:Has anyone come across this before?
    More than likely…..errrr….what model are we talking about here?
    #162595
    Twoten
    Oops!
    It’s a Bosch SGS5312GB/07
    Keith.
    #162596
    The invisible bit of glass in the drain part of the matrix……………………
    Twoten
    The invisible bit of glass in the drain part of the matrix….
    Unfortunatley not,
    Always works OK when the anti-flood switch is operated, never when it should via the control panel.
    #162598
    Anti-flood switch supplies power direct to the pump, bypassing the electronics. Therefore…. Electronics.
    gegsy
    Penguin45 wrote:Anti-flood switch supplies power direct to the pump, bypassing the electronics. Therefore…. Electronics.
    Twoten
    That was the way I saw it but wanted to make sure I hadn’t missed something.
    Thanks.
    #162601
    Twoten
    Fitted a new control module and voila the drain pump works.
    Call from customer about 2 hours later……. The machine isn’t heating, stuck on a wash since I have left and not hot.
    #162602
    Twoten
    Update to this problem………
    Returned to customer, new PCB from BSH faulty!
