Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch dishwasher not draining
- This topic has 6 replies, 3 voices, and was last updated 13 years, 4 months ago by
kjason.
December 1, 2012 at 8:30 pm #72820
kjason
ParticipantHi. I have a Bosch dishwasher which is not draining properly. It looks like the pump is OK and free from debris. It has been suggested that the problem could be that the upper spray arm connected to the upper basket is not connecting properly to the feed tube. Does this sound like a feasible reason for not draining properly? Many thanks
December 1, 2012 at 9:45 pm #385662repman
ParticipantRe: Bosch dishwasher not draining
you will need to post a model number to give us a chance but no top spray arm issue does not sound a pos reason
December 2, 2012 at 10:38 am #385663kjason
Thanks for the reply. Turns out it’s a Siemens SE64A630GB/17. Brain fade on my part (last one was a Bosch) :boops: When it first started playing up an engineer came and got it working again by putting some tape on the prong on the feed tube that fits into the upper spray arm. This worked for a while but now back to square one. As far as i can see, the connection is sound hence why i questioned this as being the reason the appliance won’t drain. thanks
December 2, 2012 at 11:26 am #385664Martin
Not draining is a drain pump/ drain outlet issue and nothing whatsoever to do with the spray arms. The spray arms are for washing and the pump for draining. :rolls:
December 2, 2012 at 12:47 pm #385665kjason
Thanks. That’s exactly why i wanted to check with the experts on this forum. This morning I took the pump cover off, removed the black rubber non return valve, put the pump cover back on and ran a quick cycle – this seemed to work fine. I then returned the non return valve and it still seems to be working OK. Should i replace the non return valve (condition looks OK to me but i am no expert) or should i just assmume it wasn’t sitting right? Thanks again for help on this forum P.S engineer wanted £63 to replace the feed tube and top spray arm despite no signs of damage 🙁
December 2, 2012 at 1:34 pm #385666Martin
It wouldn’t harm changing the non-return valve (part no: 165262) as it is less than 3 quid direct from Siemens own eShop. 🙂
December 2, 2012 at 5:57 pm #385667kjason
I will do that. Thanks again for your help
