Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch dishwasher not draining
- This topic has 13 replies, 5 voices, and was last updated 5 years ago by
suedehead1.
March 28, 2021 at 8:35 pm #99359
suedehead1
ParticipantSGV46M43GB/01. The pump was tight so I fitted a new one but it will not drain. There is no blockages . I tried removing the non return flap
but still no drain. I tried it with door open and pushed up the polystyrene float the pump runs you can see the water being displaced but it
will not drain any ideas welcomedMarch 28, 2021 at 10:20 pm #476002electrofix
Moderatorstill got to be a blockage or air lock somewhere
is the left side water way clear ?
March 29, 2021 at 6:53 am #476003suedehead1
Participanthi, yes it is cleara bit of black gunge at the top of the plastic, you can see water starting to go through it then it stops
March 29, 2021 at 7:53 am #476004oldsodchops
ParticipantCould it be blocked between the water matrix and the drain hose connection?
March 29, 2021 at 8:42 am #476005electrofix
ModeratorIf not already done I would remove outlet hose from both ends and blow down it. sounds like a fat blockage
assume the pump cover is on properly
March 30, 2021 at 6:54 am #476006suedehead1
ParticipantHi, pump cover on ok, blew down hose nothing blocking it at all
March 30, 2021 at 8:49 am #476007electrofix
Moderatorwell onto long shots now as blockages was very high up the list. assume you tried putting hose ino a bucket intead of the drain
assume the little hole in the pump cover is clear and you have already said pump cover is in place properly.
have you checked voltage to the pump, yes am clutching at straws nowDave
March 30, 2021 at 10:17 am #476008Hollytree_Technical
ParticipantJust a thought – does it need to a functioning non return valve? The pumps only bat the water out so maybe if the non return valve is not sealing off properly the water might be returning into the machine just as quick as it is batted out by the pump.
P.S. If it makes you feel better I had a similar machine soon after I started in the trade with the same issue and I never did fix it, a new non return valve was my next guess on it but the customer scrapped it first.
March 30, 2021 at 10:34 am #476009electrofix
ModeratorHollytree_Technical wrote:customer scrapped it first.
really frustrating when that happens lol
March 30, 2021 at 6:26 pm #476010roy1
ParticipantI had one this week not draining,I took the clear hose off the side tank it still would not drain into a bowl.
I pushed a cable tie from the pump into the clear hose and that looked ok, but when I put water in the sump and tried again a lump of rice shot into the bowl.
Just another thought is the replacement pump the correct part.March 30, 2021 at 7:22 pm #476011suedehead1
Participanthi thanks everyone its a genuine pump I will need to go and give it another l think the problem must lie in the matrix on the side
March 31, 2021 at 6:36 pm #476012roy1
ParticipantThere are two different pumps ,I fitted the wrong on once the pump runs but it will not drain.
April 1, 2021 at 6:28 am #476013suedehead1
Participantok i will check which pump i fitted
April 4, 2021 at 6:31 pm #476014suedehead1
ParticipantI refitted the non return valve flap and it appears to be working ok
