Bosch Dishwasher Not filling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher Not filling
  • #10015
    I have a Bosch Dishwasher model SHU4002 that does not fill with water. This happened about 2 years ago, I replaced the water inlet valve and it worked again. I tried the same approach this time, but the new valve made no difference. Any other ideas?
    #137833
    Re: Bosch Dishwasher Not filling
    The water inlet system and sump hose will most likely be blocked in this case. 😉 (what part of the world is this machine located, as this model is NOT sold in the UK) 😕
    #137834
    superfix
    It is sold here,it’s the American D/W slightly taller than the usual.
    Is there any water in the base pan of m/c?
    Pull plug first before removing panels :plug:
    #137835
    gegsy
    As Boro said and also worth a check is the 1 foot ribbed pipe from sump front to pressure chamber on l/h side; it gets gunged up.
    As always :plug:
