Bosch dishwasher not heating water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher not heating water
  • #87802
    martinjdurant
    I have an old Bosch dishwasher (SGS5002GB/07) circa 1995 It is a fairly simple machine. It is not heating the water. Research on this site (and others) suggests three causes;
    1 broken heating element,
    2 broken thermostat
    3 dry solder joints on the PCB
    I have checked the hating element and is has a resistance of 27 ohms which is within the suggested 15-30 ohm range.
    I have replaced the thermostat with a new one.
    I can’t find a PCB on the machine; it appears to me to be electro-mechanical.
    Any suggestions as to the cause of the failure or location of the PCB would be gratefully received.
    Re: Bosch dishwasher not heating water
    You’ll need to remove the control module from the door and check the PCB for burnt heater relay terminals. Simple fix with a dab of solder and a dash of TLC. 😀
