bosch dishwasher on it’s side problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher on it’s side problem
  • #80646
    dpr1974
    Evening, I don’t have the model number as i left it in the shop, but i don’t think this is a model specific problem.
    sold a dishwasher today (just over a year old) when i installed it and tested it, it showed the symptoms of a faulty inlet (anti-flood) valve. i do confess that the machine was on it’s side for a few seconds to get it passed (under) the worktop but would this cause a problem with the valve? if so, would leaving it to stand sort it out?
    I’ve not had this problem before but with some newer w/m having problems if you tilt them past 45′ i wondered if dw are the same?
    cheers
    #413598
    Used dishwasher with water filled salt reservoir and water in the inlet matrix/heat exchanger = water pi$$ing out and into the base if tilted.
    Time to get out the toolbox I reckon. If you need further help do please give model numbers first before posting. Much better 😀
