Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch dishwasher PCB pic with blown transistors
- This topic has 7 replies, 3 voices, and was last updated 14 years, 8 months ago by
Simon46.
July 23, 2011 at 8:58 am #64101
Simon46
ParticipantBosch SHV43A03GB/42 Dead. Anyone know what has blown the two transistors on the pic?
http://i235.photobucket.com/albums/ee14 … marked.jpgRegards
SimonJuly 23, 2011 at 9:08 am #356049Martin
ParticipantRe: Bosch dishwasher PCB pic with blown transistors
Simon46 wrote:Anyone know what has blown the two transistors on the pic?
If you follow the track from the triac/transistor down to the terminal connector block and see what it supplies, then you have your answer. As a rules it’s either the water point diverter motor on the heater box OR the dispenser release solenoid that blew it.
A quick bit of detective work sussing out which lead goes where will locate the ‘orrible truth. 🙁
July 23, 2011 at 10:45 am #356050Simon46
Yes had a quick smell of the dispensor solenoid and metered across it Whilst door was off. No shorts or burning smell. Possibly need to drag it out and inspect divertor. 🙁
Looks like profit gone from job. 🙁
S.July 27, 2011 at 3:25 pm #356051Simon46
On further visit found a little dirty water in base and yellow stain under diverter motor. Not taking chance so replacing heater box and dispenser solenoid along with module.
S.July 27, 2011 at 3:55 pm #356052Martin
Blimey! Well if you’re going to that much trouble be sure to change the circl. pump impellor kit too while you’re there! 😀
July 27, 2011 at 6:41 pm #356053nomadPaul
The bottom one is definitely the water point actuator . The dispenser actuator is the one to the left of that one .
The 3 on the right…from top to bottom = Drainage valve , regen valve , filler valve.
No idea what the top chip is that you’ve indicated as blown
July 28, 2011 at 5:27 am #356054Simon46
Top chip is a transistor and the tracks go to the blown bottom transistor. Must have taken it out when it blew. Cheers for the info on what controls what Paul.
Will leave impeller til next time 😆
S.July 29, 2011 at 4:34 pm #356055Simon46
Many thanks Guys. Quite enjoyed my first diverter heater box replacement.I did turn it on its head!
S.
