Bosch dishwasher problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher problem
  • #68408
    gartril
    I have a Bosch SHV55MO3GB/55 dishwasher approx 6yrs old. Tablet is not disolving, machine not switching off, keeps rinsing. I have replaced the control module but problem still persists. Any thoughts?
    #370964
    Re: Bosch dishwasher problem
    gartril wrote:Any thoughts?
    Loads of thoughts actually….you went to the expense of changing the board in an attempt to cure the problem?…wow big mistake!
    “Keeps rinsing” you say…by that would I be right in thinking that water comes in and drains out almost immediately?
    #370965
    gartril
    HI martin, thanks for the quick reply. Yes, expensive mistake £130. Machine seems to complete cycle,but keeps going. When door is opened display shows 1min. Tablet not disolved. have tried on all programmes,all sounds OK until what should be end of cycle then pump can be heard running, leaves small amount of water in bottom filter, impeller ok all filters cleaned.
    #370966
    The problem is likely associated with lack of water into the machine. That could be due to the water inlet matrix blocked, the impellor jug gone AWOL or the base tray flooded. That’s enough for you to get stuck in and check those out for now.
    If you want a bit of expert help then do please call in a local independent engineer, could save you loads of time, money and hearthache. Simply click on the ‘Find an engineer’ icon.
    All the best…!
    #370967
    gartril
    Cheers Martin. I’ll check what you advise. I think the engineer is the best solution.
    Thanks again.
