Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Dishwasher pumps
- This topic has 14 replies, 6 voices, and was last updated 19 years, 4 months ago by
reddogwood.
December 12, 2006 at 1:24 pm #23306
reddogwood
ParticipantHi, can anyone advise me if pump 187970 could be replaced by pump 165261? as I’m about to order one but 187970 is out of stock but 165261 is in stock, they look similar in photo’s
Regards Paul
December 12, 2006 at 1:47 pm #197692gegsy
ParticipantRe: Bosch Dishwaher pumps
I wouldn’t think so IMHO, as these are two different part numbers for a reason I would think.
Did you try an email to spares@ukwhitegoods.co.uk ❓ 😀Greg
December 12, 2006 at 1:59 pm #197693reddogwood
Thanks Greg
Just sent them an emial
Paul
December 12, 2006 at 2:01 pm #197694reddogwood
PS
What’ IMHO ❓
Paul
December 12, 2006 at 2:26 pm #197695gegsy
I n
M y
H onest
O pinionGreg 😉
December 12, 2006 at 2:43 pm #197696reddogwood
AH,AH
Paul 8)
December 12, 2006 at 3:06 pm #197697Martin
reddogwood wrote:they look similar in photo’s
The impellor blades are different and not interchangeable! 😉
December 12, 2006 at 6:33 pm #197698reddogwood
Thanks Martin
Regards Paul
December 12, 2006 at 11:05 pm #197699reddogwood
Martin wrote:
reddogwood wrote:
they look similar in photo’sThe impellor blades are different and not interchangeable! 😉
Just an after thought Martin.what kind of affect would the different impeller cause, slower draining rate?
PaulDecember 12, 2006 at 11:46 pm #197700nationalhomecare
ParticipantRe: Bosch Dishwasher pumps
Hi!
Just to add…….
187970 is fitted to the SGS GV600 range, This is the one with the tin base that has acces from underneath to motor,pump heater box etc and plastic inside the machine
165261 is fitted to the SGS range with the plastic chassis and all stainless inside/acess to pump impellor from sump cover inside machine.
The impellors are very different and as far as i know are not interchangable, should imagine discharge rate would be affected as shape of impellor wouldn’t match housing?
Sorry to be a sad anorak 😳
But, hope its of some help 😉
nationalhomecareDecember 12, 2006 at 11:51 pm #197701reddogwood
Oh well thanks anyway
Paul 🙁
December 13, 2006 at 8:58 am #197702goosegreen
187970 Seems to be in stock with Connect at £29+
Goose
December 13, 2006 at 9:05 am #197703Martin
goosegreen wrote:187970 Seems to be in stock with Connect at £29+
Best try BSH directly then as they are only £28.10 + VAT retail!
December 13, 2006 at 5:48 pm #197704silverbroom
BSH will give you 15{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} discount if you are bonafide trade, worth asking or if you order online anyone gets 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} off.
Victor.
December 13, 2006 at 8:00 pm #197705reddogwood
Thanks Guy’s
Ordered one from http://www.Partcenter.co.uk (Wolseley) formerly washvacs at
£23.10 + v.a.tRegards Paul 🙂
