Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Dishwasher pumps
- This topic has 8 replies, 4 voices, and was last updated 14 years, 9 months ago by
whiskeyjack6058.
June 28, 2011 at 8:26 pm #63644
whiskeyjack6058
ParticipantI went out to a plastic tub Bosch dishwasher today which needs a new drain pump. I didnt have one with me, looked at the price of them on Connect and almost had heart failure.
The enr is SGS43T52/16 FD number 8512 10294.
I have a drain pump (electrupart) push and twist style which cost me about £11+vat but it’s the one for the steel tub. Looked and compared them on screen and they look very similar apart from the impellers are not cut at an angle on the plastic tub version.
Does anyone know if this will fit with success?
Thanks,
Rob.June 28, 2011 at 10:58 pm #354390leavemetogetonwithit
ParticipantRe: Bosch Dishwasher pumps
Electrue part straightforward equivalent in stock £11.10. PMP9139. How did you miss that?
Mike.June 29, 2011 at 7:29 am #354391whiskeyjack6058
Hi Mike – pmp9139 is the pump designed for the steal tub version. A bit further along the search there is a different pump which is the type fitted to the plastic tub version (5031686444166). I have the pmp9139 in stock which is why I would like to know if it will go on without issues. The impellers are different…
Rob.June 29, 2011 at 9:30 am #354392leavemetogetonwithit
I see what you mean. Is the steel tub version a different forward slash number?
My gut feeling would be that the chambers must be shaped differently, so it might work but if it does it would probably not be as efficient. Masterpart have it £28.46.
Mike.June 30, 2011 at 8:30 am #354393leavemetogetonwithit
Just found this whilst looking for something else.
Don’t know how reliable the information is. Part is a secondhand one by the way.
http://www.casaparts.co.uk/products/id-14121001
Mike.June 30, 2011 at 12:50 pm #354394whiskeyjack6058
That helps loads!!! Thank you! I have also added a bookmark to that site!
Cheers,
Rob.June 30, 2011 at 1:04 pm #354395Martin
Though I’ve never ever replaced a pump on a plastic tub dishwasher, I wouldn’t mind betting the conventional stainless tub pump would fit and work just as well?
I’ll try out my theory and report back……… 💡
June 30, 2011 at 2:19 pm #354396PINKY
Pump works fine from one to the other!
PinkyJune 30, 2011 at 4:48 pm #354397Martin
PINKY wrote:Pump works fine from one to the other!
Thought as much….cheers Pinky! 8)
