Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Dishwasher puzzling water inlet fault
- This topic has 5 replies, 5 voices, and was last updated 9 years, 4 months ago by
subs.
November 16, 2016 at 7:01 pm #89884
subs
ParticipantSGV53E23GB/90
FD8801
This job has got me banging my head against the wall. Starts off it’s not letting in water, check inlet valve and it’s open circuit so nice simple job. Fit valve and as it starts to let in water after a while it starts spurting out the top of the plastic water matrix. After some head scratching i realise that the regeneration unit is all clogged up with hardened salt. So come back and fit new salt unit. Test it and it starts filling nicely with water, but it keeps filling and filling over the correct level until it overfills and operates the outlet pump and keeps filling and emptying a bit simultaneously. The wash pump doesn’t kick in but the check water light comes on. Tried new inlet water indicator but still same thing. So it says check water but keeps filling. I’m thinking the inlet valve might have done the board when it went open circuit although there are no visual signs on the board.
Any ideas please?Thanks
Subs
November 16, 2016 at 10:38 pm #442882Gary59
ParticipantRe: Bosch Dishwasher puzzling water inlet fault
Overfilling will be the flow meter at the rear, fitted quite a few.
November 16, 2016 at 11:18 pm #442883eastlmark
ModeratorRe: Bosch Dishwasher puzzling water inlet fault
subs wrote:SGV53E23GB/90
FD8801
ThanksSubs
does this mean you changed the impellor jug between the valve and the air break? Most likely cause.
November 17, 2016 at 12:25 am #442884subs
Hi, I changed the impeller jug and still same problem. Changed lots of these before and normally when it’s this it starts to fill but when the pc board receives no signal it shuts off water. This just keeps filling.
Subs
November 17, 2016 at 10:27 am #442885Martin
It wouldn’t just be that the microswitch on the float chamber is either faulty or the connector block to it is misplaced would it?
November 18, 2016 at 2:45 pm #442886Dan76
I had one do this exact fault a few weeks go.
Its the float switch sticking. It comes as a kit.
Dan -
