Re: BOSCH dishwasher replacing sump seal SMV50E00GB/13
Hiya
Did one of these a month or so ago, not too bad once the plastic base is off-
unhook door springs & bend out tabs on s/s tub to release base.
Remove heat pump , drain pump & Distributer & pipes
I did replace the Distributer as well as i was concerned about the old O ring not fitting- & it didn’t !
A bit daunting at first , think it took about 1.5 hrs, & no leaks afterwards, thankfully.
Clive
