bosch dishwasher sgs3062gb/01 spray arms sticking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher sgs3062gb/01 spray arms sticking
  • #78995
    DDA
    There are no blockages in the arms in any jets or the axle / pivot. there are no obstructions from the baskets.
    the top arms seem to be getting stuck in the same position.
    it seems like the arms are unbalanced and one side raising and pushing against the basket.
    The bottom arm occasionally moves but keeps stopping.
    i was going to order both arms in case worn, but wanted to be sure as isn’t any obvious damage / wearing.
    as always all help will be appreciated
    Anthony
    #407552
    Re: bosch dishwasher sgs3062gb/01 spray arms sticking
    Water point diverter faulty, needs heater replacing.
    #407553
    DDA
    Do u mean the spray arm selector on the heater? i have checked this but there doesn’t seem to be one on this model
    #407554
    pmb
    Hi is the machine filling with enough water? it should be lapping the salt lid. if it is I would try the spray arms. I have never had to change the bottom one but the top ones do wear. I hope this helps
    #407555
    DDA wrote:Do u mean the spray arm selector on the heater?
    You are correct ,I’ve just checked and there isn’t one on this old beast. So, in that case it could be that there is something caught in the circulating pump Impellor (assuming of course that it fills with the correct amount of water?). With both spray arms removed water should flow like an elephant peeing anyway. 😀
    #407556
    DDA
    managed to sort the problem and thought id update,
    had another look and after several more attempts at clearing the spray arms i managed to fish a few more bits of sweetcorn out witch has sorted the problem. thanks for all the advice, feel stupid but glad i took the second look.
    Anthony
    #407557
    Sweetcorn, blimey. :rolls:
