Re: Bosch dishwasher (SGS4332GB) – not using hot water
hi
there are a usually few reasons why these dont heat
1 not enough water in the appliance
2 module faulty
3 heater open circuit
they usually happen in 1,2,3 order as well
check to make sure it is filling correctly (when washing the whole of the bottom of the tank will be covered in water,)
*****POWER OFF BEFORE ATTEMPTING THE FOLLOWING STEPS*****
check the control module, power for the heater comes from the thick red wire on the module so remove it and open the plastic case and check for dry joint where the red wire joins the module
using a test meter check the element and thermostats (NCTs)
hope this helps
linrew
