Bosch Dishwasher SGS43A22GB stops mid cycle!?!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher SGS43A22GB stops mid cycle!?!
Viewing 15 posts - 1 through 15 (of 23 total)
  • #34465
    GuyP
    Hi folks
    I hope you can help. I have a Bosch dishwasher SGS43A22GB that will fill with water but then stops (on all the cycles). When you open the door you can see the water in the bottom. Nothing else happens! I press the start/stop button and the pump activates and the water drains away. Can anyone help me get it to do the dishwashing bit!?!?
    Thanks in advance for any help you can give me.
    Guy
    #242750
    gegsy
    Re: Bosch Dishwasher SGS43A22GB stops mid cycle!?!
    Possibly a jammed/seized wash pump or start capacitor failure (on side of wash motor)
    Power off if you are to investigate :plug:
    GuyP
    Thanks for replying Greg
    Where do I find these bits on the machine and how can I tell which is defunct?
    Guy
    #242752
    GuyP
    Hi Greg
    The full model number reads: SGS43A22GB/01. There is another number in smaller font above which is SD15K1B? The SGS number is repeated again without the /01 bit underneath. The machine is about 4-5 years old from new if that helps.
    Cheers
    Guy
    #242753
    gegsy
    Easiest way with this one is, power off then lie it on some towels on its back (watching not to trap or put any of the hoses under duress)
    Remove the steel plate base cover, it usually clips off at the front or maybe held on by two torx 20 screws.
    With that removed you can gain access to what you need. The big motor is your wash pump and the silver cylinder attached to body is the capacitor 😉
    mr rugby
    Although I do not have your model of dishwasher, on a previous occasion that I had a stuck system it turned out to be the anti flood switch had activated.
    This seems to prevent anything working other than the pump to empty the system.
    Have you checked that no water has collected in the base, due to a leak.
    I’m assuming your’s works on the same principle has mine.
    mr rugby
    #242755
    gegsy
    mr rugby wrote:on a previous occasion that I had a stuck system it turned out to be the anti flood switch had activated.
    GuyP wrote:When you open the door you can see the water in the bottom. Nothing else happens! I press the start/stop button and the pump activates and the water drains away.
    #242756
    mr rugby
    I meant in the drip tray underneath the sump.
    I don’t mean the actual dishwasher sump where the water collects and where the spray arms are located.
    Mine has a waterproof drip tray below the entire dishwasher.
    A float device is activated should water enter the drip tray and this will only allow the pump to empty the dishwasher. Nothing else works.
    Again i’m not sure if the bosch works on the same principle.
    mr rugby.
    #242757
    gegsy
    Yes it does have a drip tray and if it had been activated he would not have had any water in the tank when he opened the door, is what I was trying to say 😀
    mr rugby
    point taken
    mr rugby
    #242759
    northener
    I’ve had what seems to be a similar problem repaired on my Bosch SGS6302 (9 years old). The machine switched on, selected a program, filled with water, and then sat there doing nothing. When switched off (by ending the cycle by pressing the Intensive and Eco switches together) the water drained.
    It was as suggested above – the motor capacitor had failed.
    Hope this helps.
    #242760
    GuyP
    Thanks for the tip and thanks to evryone else for their advice. Tied up with work at the moment but this is my project for the weekend!! Any tips on how I can tell which bit is gone?
    Guy
    #242761
    GuyP
    Hi folks here’s an update.
    Took everything apart as suggested and cannot see anything wrong. Had a look in the machine again and took out the filters etc and no problems there.
    Are there any tests I can do to tell whether it is the wash pump or the capacitor as both appear fine on the outside (could be a bag of bits inside!)? Do I now need to get an engineer in?
    Thanks again for all the help so far.
    Guy
    #242762
    gegsy
    Cheapest option is change the capacitor, its the most likely and most inexpensive 😉
    GuyP
    Thanks Greg
    Had a look on the find a part bit of this site but there are no bosch capacitors listed (only a radio interference device which does not look like the part I need)? Do you know where I might get one?
    Guy
