Bosch Dishwasher SGS43E02gb
  • #42583
    johnnyhoz
    Hi all
    Had a look at this dishwasher today its making a Loud Clicking ticking noise coming from the heater element area during the whole program even when the program has finished it sounds like a small motor running from in or behind the heater enclosure looking from the right hand side of the machine.
    The washer appears to be working ok although the customer said on one occasion the tablet did not dissolve, I tried every program and it heated ok.
    Any ideas please what could be causing this noise ?
    John
    #274041
    TELL
    Re: Bosch Dishwasher SGS43E02gb
    could be the little motor which distributes the water from top arm, and then to bottom arm, could explain why tablet not disolving.
    TELL..
    #274042
    johnnyhoz wrote:during the whole program even when the program has finished it sounds like a small motor running from in or behind the heater enclosure looking from the right hand side of the machine
    How about the water point diverter motor under the heater causing the noise maybe? Although can’t imagine why it would do it when the programme has finished though? 😕
    #274043
    johnnyhoz
    Thanks Martin & Tell
    on the drawing looks like this motor is complete in the heater housing part number 483058 (compl.w.aqua sensor,NTC,push switch + altern.water distributor ) can’t see another motor, is this the one you guys are talking about ?
    The only thing I’m puzzled about is should this motor be running after the program has stopped and if not does this mean there could be a fault with the control module as well ?
    John
    #274044
    TELL
    Technically it should have all shut down, at the end of programme and no power to motor, as with the control board should end prog. but if you trace the wiring back from the motor(which is like a little turntable motor) then you can check if voltage is still getting to it.
    TELL..
    p.s. i dont think these come seperate, and are bit pricey.
    #274045
    BobHope
    its possible the motor is jammed in an open position with food or glass paticals and it is still trying to return to its normaly parked position.
    Bob.
    #274046
    johnnyhoz
    Thanks for all your help and advice I now have something to go on
    Cheers
