Bosch Dishwasher SGS43T52GB/21 overheating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher SGS43T52GB/21 overheating
  • #33565
    bobokines
    Bosch Dishwasher SGS43T52GB/21 FD8510 006761
    Hi guys, This dishwasher is not advancing from the heat pause. I tested in on a 35C progrram and it got to over 50C before I turned it off. the customer reported that it was still washing —very hot— after three hours.
    It is 25 months old.
    Does anyone have any ideas. I would have thought that if it was the ntc at fault it would have aborted the heat pause early. My instinct is the module.
    Does anyone have a wiring diagram please so that I can check the NTC connection to the module first.
    Many thanks
    Bob
    #239187
    bobokines
    Re: Bosch Dishwasher SGS43T52GB/21 overheating
    Anybody able to help here please…
    Bob
    #239188
    bobokines wrote:Does anyone have any ideas. I would have thought that if it was the ntc at fault it would have aborted the heat pause early. My instinct is the module.
    Not sure Bob but I would have thought the NTC the likely suspect? Though I’ve never had NTC failure on a Bosch d/w so far at least? Mouse chewed wire maybe? 😕
    The base comes off on these so dropping the heater box to access the NTC is a simple task. Also tracing the wiring back to the module pretty straightforward so you can check for continuity etc. 😉
    All the best!
    #239189
    bobokines
    Thanks mate, I’m going back on monday. I’ll let you know the outcome.
    Bob
    #239190
    gegsy
    Hi Bob
    You have mail 😉
    bobokines
    Thanks Greg, most helpful
    Bob
    #239192
    bobokines
    I think this must have been a bad connection on the module.
    After checking all the wiring and checking the NTC resistance from the module end, the damn thing now works OK.
    Thanks again for the info.
    Bob
