Bosch Dishwasher SGS43T62GB/73 check water led
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher SGS43T62GB/73 check water led
  • #51993
    Bernie
    Selected rinse starts to fill after about 30 seconds the “check water” led comes on it continues to fill only then it starts to drain but in spurts. You can see the water in the float chamber going up and down which then activates the micro switch.
    Is “check water” led a fault code? If so what is it, if not what does it mean?
    Or any other suggestions please
    Bernie
    #310227
    nomadPaul
    Common fault Bernie – It1ll be the flow rate meter ( impellor jug ) part no: 424099.
    Its the while cylindrical component fitted on the inlet hose between the water matrix on the left and the inelt hose itself.
    #310228
    Bernie
    Re: Bosch Dishwasher SGS43T62GB/73 check water led
    Very Many Thanks to you nomadPaul
    Bernie
