Bosch dishwasher SGS43T72GB
  • #71876
    qcarelsen
    Hi guys,
    Went to above appliance today and it had a fault I haven’t seen before so any help will be appreciated. The appliance starts filling with water, and it sounds like it filling fine, good pressure etc. while filling the check water light comes on, but it keeps filling, it doesn’t stop filling. It then fills a bit and pumps water out a bit then fills a bit and pump out a bit, and that keeps going and going.
    Has any one came across this problem yet, I am tempting to think its the PCB, and could not see a flow meter in this one, I know it must have one but couldn’t see it.
    Thanks guys,
    Quintin.
    #382649
    Rograbbit
    Re: Bosch dishwasher SGS43T72GB
    Just looked on the Bosch site. There is an impellor jug fitted on that model. First thing to change. Very common. Part number 424099. 😀
    #382650
    qcarelsen
    Thanks Rog, I will give that a try.
    #382651
    qcarelsen
    Any possibility some one has got a drawing for this machine so I can see where this Impellor sits. Cheers.
    #382652
    Hollytree_Technical
    It is fitted between the inlet valve (mounted on the back panel of the machine) and the tank in the side – trace the blue hose back from the tank and you will find it (rear left corner).
    Jem
    #382653
    qcarelsen
    Thanks Jem, sounds easy enough.
