Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Dishwasher SGS5342GB/17
- This topic has 6 replies, 4 voices, and was last updated 19 years, 10 months ago by
johnnyhoz.
May 23, 2006 at 9:07 pm #18024
johnnyhoz
ParticipantI attended the above dishwasher which wasn’t draining, checked all the hoses, filters etc for a blockage, nothing found, fitted a new pump, not much improvement !!
the water inlet chamber looked fairly grotty up by the breather but that flushed out with not too much trouble, but still the water is pumping away very slowly
any ideas ?
JohnMay 23, 2006 at 9:10 pm #177429Penguin45
ParticipantRe: Bosch Dishwasher SGS5342GB/17
Glass in the drain chamber – it’s caught me out more than once.
May 23, 2006 at 9:17 pm #177430gegsy
Have you checked spigot, drain hose attaches to under sink for blockages?
May 23, 2006 at 9:34 pm #177431johnnyhoz
thanks for your swift replies I thought I’d be the only silly bugger up at this time.
The drain hose is straight into a down pipe so spigot Greg, thanks anyway.
when you say the drain chamber do you mean the sump area Chris? I have taken the removeable cover off and even tried running the machine without the rubber valve but no difference. I have been poking my fingers down the holes around the drain pump impellor but felt no glass in this area, I pushed a lenghth of 1/4 rubber hose up the drain hose from each end but felt no resistance.May 23, 2006 at 10:08 pm #177432bobokines
I have been caught here! Twice!
Remove the left hand side panel and follow the hose from the anti-syphon tank to the pump. You will find a floating blockage in the hose.
I have had a cashew nut shell that floated in the water (and acted as a one way valve) and a piece of plastic from the top of a carton of orange juice.
Good luck
Bob
May 23, 2006 at 10:46 pm #177433Penguin45
johnnyhoz wrote:
when you say the drain chamber do you mean the sump area Chris?No – the other half of the fill chamber on the left hand side – front half for fill, rear half for drain. Bob’s theory is equally valid – I’ve had that one a few times as well.
May 24, 2006 at 7:55 am #177434johnnyhoz
Thanks for the advice guys
John
